#1 Thu 14 June 2007 09:41
Ph.loussot
QGIS 0.8.1 : Fenetre de saisie de polygone qui disparait
lorsque je saisi un nouveau polygone, la fenetre de validation remonte à chaque validation et a fini par dispraitre ...
cela prette à rire, sauf que les coordonnées de la fenetre ne sont pas stable sur l'écran. Un collègue à eu le même problème, mais je n'arrive pas à l'appliquer à mon propre cas (mon anglais est bien lamentable)
ceci explicant peut être cela.
qui peut me dépanner
Enter attribute values window has crawled off the screen
I'd appreciate any help I could get on this. I installed version 0.8.0 of QGIS on a windows XP machine. Data loads perfectly and overall it looks like a great tool. I was creating some vector data using teh tools and the "Enter Attribute Values" window has crawled off the screen. I installed it on another machine to see if it would do the same thing and I noticed that everytime I added a point or polygon and the EAV window would show up it would climb a little higher on the screen than it had been before. Once it moved to where the top of the bar was off the screen it can't be brought back down. Has anyone seen this same error or does anyone have a solution?
Thanks for the anticipated help.
I managed to get the form back on my screen by changing the X and Y values in my registry (I found them under My Computer -> HKEY_Current_User -> Software -> QuantumGIS -> qGIS -> Windows -> AttributeDialog as values X and Y. Setting both of these to 0 puts the window back on your screen, where you can move it further down on your screen. On my Windows XP Machine it looks like everytime the window pops back open it is moving up by the height of the title bar and over to the left by the width of the frame.
Hope this helps someone else out there.
#2 Thu 14 June 2007 10:12
Yves
Lieu: Aix-les-Bains
Re: QGIS 0.8.1 : Fenetre de saisie de polygone qui disparait
Voici une traduction rapide, pour la partie propre au système windows, vous devrez trouver la correspondance en français.
La personne a modifié la base de registre en changeant les valeurs X et Y (trouvé sous My computer -> HKEY_Current_User -> Software -> QuantumGIS -> qGIS -> Windows -> AttributeDialog), définissez les à 0. À chaque ouverture de la fenêtre, celle-ci se déplace de la hauteur et de la largeur de ladite fenêtre.
#3 Thu 14 June 2007 11:05
Ph.loussot
merci,
mais justement c'est l'accès à ces commandes que je n'arrive pas à trouver
merci pour coup de main
#4 Thu 21 June 2007 17:25
Carine
Lieu: HAUTEVILLE LOMPNES
Il faut aller dans Démarrer>Executer puis taper regedit, et changer les valeurs à 0 sous le chemin indiqué. Et ça marche, j'ai eu le même problème !
