#1 Tue 31 October 2023 18:21
QGIS/Plugin spectral-libraries: message d'erreur installation
Je travaille avec Qgis 3.32.2-Lima sur Ubuntu.
J'aimerais pouvoir utiliser ce plugin :
https://plugins.qgis.org/plugins/spectral_libraries/
Mais il semble obsolète ?
En tout cas, lorsque j'essaie de l'intaller via qgis, j'ai un message d'erreur (ci dessous).
Si ce plugin n'est plus fonctionnel, connaitriez vous des alternatives ?
Impossible de charger l'extension 'spectral_libraries' provoque une erreur lors de l'appel à sa méthode classFactory()
ModuleNotFoundError: No module named 'mock'
  File "/usr/lib/python3/dist-packages/qgis/utils.py", line 423, in _startPlugin
    plugins[packageName] = package.classFactory(iface)
  File "/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/spectral_libraries/__init__.py", line 14, in classFactory
    from spectral_libraries.spectral_libraries_plugin import SpectralLibrariesPlugin
  File "/usr/lib/python3/dist-packages/qgis/utils.py", line 888, in _import
    mod = _builtin_import(name, globals, locals, fromlist, level)
  File "/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/spectral_libraries/spectral_libraries_plugin.py", line 29, in
    from spectral_libraries.interfaces.spectral_library_gui import SpectralLibraryWidget
  File "/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/spectral_libraries/interfaces/spectral_library_gui.py", line 34, in
    initResources()
  File "/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/spectral_libraries/qps/__init__.py", line 154, in initResources
    from .testing import initResourceFile
  File "/home/geoteca/.local/share/QGIS/QGIS3/profiles/default/python/plugins/spectral_libraries/qps/testing.py", line 40, in
    import mock
