#1 Sat 15 April 2017 14:27
Patrice
ACAD MAP 201X-202X - Tech Infos Divers
Hello
Qq Infos diverses sur AutoCAD MAP 201X-202X ...
GeoBye, Pat
----- PS: les champs OD (Object Data) de type String/Caractere sont TOUJOURS limites a 132 caracteres -----
RAPPEL voir ici le Forum English AutoCAD MAP :
https://forums.autodesk.com/t5/autocad- … -map-3d-en
RAPPEL : Ne pas oublier que depuis la version 2016, les SPs des versions Metiers sont specifiques a la version Metier !
Donc par exemple sur un AutoCAD Metier 2016-2017-201X, il faut penser a installer le SP1 de AutoCAD 2016 / 2017
PUIS installer le SP specifique a AutoCAD MAP 2016 / 2017, ACAD Archi 2016 / 2017, etc ...
PUIS les Updates ...
---- Hotfix pour les cartes BingMaps v8 et AutoCAD/LT/MAP/CIVIL/etc 2015-2018 ----
https://knowledge.autodesk.com/support/ … tml?v=2018
**** https://accounts.autodesk.com/ **** Gestion/Console Autodesk ****
**** System Requirements (for Autodesk Software) ****
https://knowledge.autodesk.com/support/ … quirements
**** System requirements for AutoCAD Map 3D ****
https://knowledge.autodesk.com/support/ … ap-3D.html
---- AutoCAD MAP 3D Features ----
https://help.autodesk.com/view/MAP/2026 … 2C888A800A
---- ACAD MAP 3D 20XX ---- Map 3D Documentation ----
https://knowledge.autodesk.com/support/ … ation.html
---- Key features of AutoCAD 2026 ----
https://www.autodesk.com/products/autocad/features
---- Nouveautes AutoCAD Map 3D Update 2024 ----
https://help.autodesk.com/view/ACD/2024 … 0D6813D66B
---- Nouveautes AutoCAD Map 3D Update 2023 ----
https://help.autodesk.com/view/ACD/2023 … 0D6813D66B
---- AutoCAD Map 3D Update 2023 ---- MAP 2023.0.3 ---- Sept 2022 ----
https://help.autodesk.com/view/MAP/2023 … 0_1_UPDATE
---- Nouveautes AutoCAD Map 3D Update 2022 ----
https://help.autodesk.com/view/MAP/2022 … F306B12AFC
---- AutoCAD Map 3D Update 2022 ---- MAP 2022.0.1 ---- 23 sept 2021 ----
https://help.autodesk.com/view/MAP/2022 … 0_1_UPDATE
---- Nouveautes AutoCAD Map 3D Update 2021 ----
https://help.autodesk.com/view/MAP/2022 … A3617FDA1B
---- AutoCAD Map 3D Update 2021 ---- MAP 2021.0.1 ---- 22 sept 2020 ----
https://help.autodesk.com/view/MAP/2021 … 0_1_UPDATE
**** MAP 2021 **** New in This Release
https://knowledge.autodesk.com/support/ … B-htm.html
**** MAP 2020 **** New in This Release
**** MAP 2019 **** New in This Release
**** MAP 2018 **** New in This Release
**** MAP 2017 **** New in This Release
**** MAP 2016 **** New in This Release
**** MAP 2015 **** New in This Release
**** AutoCAD MAP 2014 **** New Features ****
https://forums.autodesk.com/t5/autocad- … -p/3878147
This release of AutoCAD Map 3D includes customer focused enhancements across all AutoCAD Map 3D, including:
Industry models and utility specific capabilities
Extract and merge data between AutoCAD Map 3D and AutoCAD Utility Design
Import data from geospatial features and DWG features into industry models
Export to AutoCAD capabilities
Expanded and enhanced coordinate system library and engine
Many more enhancements with focus on performance and customer experience
This release of AutoCAD Map 3D also includes cloud integration features, including:
Support for A360 storage, synchronization, and access anywhere
Live access to commercial basemap service for aerial and road data (in conjuction with AutoCAD)
======== Les nouveautes MAP 2021 - RESUME ========
---- Les Micro-Evolutions de MAP 2021 sont :
- Edit ArcGIS Features (A priori IDEM InfraWorks !?),
- FDO WMTS Support,
- FDO SQLite 3.27.2 Support,
- FDO Oracle 19c (19.3) Support,
- Diverses micro-micro-corrections.
======== Les nouveautes MAP 2020 en US/English ========
**** MAP 3D 2020 New Features ****
From the HELP page >>>
**** Autodesk Connector for ArcGIS
AutoCAD Map 3D 2020 toolset allows you to access your GIS data on ArcGIS Online or Portal for ArcGIS Enterprise and bring them into your drawings. After adding the data to your drawing, you can view the features in the canvas, check the records in the data table, stylize the layers, and query to filter the data. For the current release, you cannot edit the data from ArcGIS Online or Portal for ArcGIS Enterprise. You can check the related topics in Help for more details.
**** Coordinate System Enhancements
The following issues are now fixed in this release of AutoCAD Map 3D 2020 toolset:
Nova Scotia coordinate Reference System (NSCRS):
NS.NAD83.2010.UTM.20N
NS.NAD83.2010.MTM.5
NS.NAD83.2010.MTM.4
NS.NAD83.1997.MTM.5
NS.NAD83.1997.MTM.4
NS.ATS77.MTM.5
NS.ATS77.MTM.4
Transformation from OSGB1936 to ETRS89
Deutsche Bahn Reference Syetem
Large size GSB files
**** Added support for:
GDA2020 Grid Transformation
Rocky Mountain Tribal Coordinate Reference System (RMTCR)
**** Other Enhancements
Extended support for the following FDO providers to newer versions:
FDO MySQL Provider: MySQL 8.0
FDO ArcGIS Provider: ArcGIS 10.6.1, ArcGIS 10.5
FDO SQL Server Spatial Provider: MS SQL Server 2017
FDO Oracle Provider: Oracle 18c (18.3)
Note: Due to a known problem that exists from Oracle 12.2, users must follow the workaround described here to work with the industry models job in Oracle 12.2 or Oracle 18c: Configure the system with "_allow_insert_with_UPDATE_CHECK" set to True, by executing the following SQL command:
ALTER SYSTEM SET "_allow_insert_with_update_check"=TRUE scope=spfile
Then, restart the database.
Support Middle Point Grip for polygons with interior rings.
A new command MAPNORTHARROWDEFAULTNORTH is introduced in this release. It allows the user to specify whether the North Arrow points to the default north (i.e., the angle of Pi/2) or the north defined in the current coordinate system. When this command sets to 0, the North Arrow will point to the north defined in the coordinate system. When this command sets to 1, the North Arrow will point to the default north.
Enhanced the Industry Module Plot.
**** The following customer issues have also been resolved in AutoCAD Map 3D 2020 toolset:
Some of the WFS data got flipped in AutoCAD Map 3D toolset. To solve this problem, in the Data Connect dialog, a new checkbox ‘Invert Axis’ is provided to allow you to specify whether to invert the axis when handling the WFS.
For some WFS service, query the data by ‘Locate on map’ option didn’t work.
The command MAPTOACAD took a long time for some specific data.
After exported to DWG, the circle symbols got stretched or compressed depending on zoom level.
The input values like line thickness, the rotation would change when users change the symbol.
Relative Orientation for Utility Point label did not work well for SQLite based industry models.
AutoCAD Map 3D 2020 toolset added some Autodesk.Map.IM namespaces to the Form Controls: Formula Box and Script-Programmable-Control.
Import from Excel lacked a detailed error message.
Intersection Area/Point did not remove deleted/moved feature if using "intersect over the area."
AutoCAD Map 3D toolset could not save projection code to the drawing.
======== Les Nouveautes MAP 2019 en US/English ========
**** MAP 3D 2019 New Features ****
**** New in This Release ****
The 2019 release of AutoCAD Map 3D contains customer-focused enhancements across the product, including the following specifics.
**** Support Mid-Points Grips on Polygon
AutoCAD Map 3D 2019 now supports the mid-point grips on polygon features. The editing options for mid-point grips are: stretch, add vertex, convert to arc and convert to line.
**** Import/Export support for CityGML and Google KML Files
AutoCAD Map 3D 2019 enables users to import CityGML and Google KML data and export data to CityGML and Google KML file format.
The following are the enhancements to the coordinate system in AutoCAD Map 3D 2019:
Support for Nova Scotia coordinate systems:
NS.NAD83.2010.MTM.5
NS.NAD83.2010.MTM.4
NS.NAD83.1997.MTM.5
NS.NAD83.1997.MTM.4
NS.ATS77.MTM.5
NS.ATS77.MTM.4
Useful range of 8 Minnesota County coordinate systems
Support for Australian GDA 2020
Deprecated 221 Wisconsin County HPGN coordinate systems
Update to EPSG 9.0
Support the transformation from OSGB1936 to ETRS89
Added Deutsche Bahn Reference System and related coordinate systems
**** New Version Support for FDO Oracle Provider
Extended support for the FDO Oracle provider to newer versions:
FDO Oracle Provider: Oracle 12.2.0.1
Note: Due to a known problem in Oracle 12.2, users have to follow the workaround described here so as to work with the industry models job in Oracle 12.2:
Configure the system with "_allow_inserts_with_UPDATE_CHECK" set to True, by executing the following SQL command:
**** High Resolution (4K) Monitor Support
Some icons in the Ribbon and Status Bar have been updated to ensure the best possible viewing experience in Dark and Light theme on 4K and higher display monitors.
The following customer issues have also been resolved in AutoCAD Map 3D 2019:
Increased memory usage for the generate graphic operation.
Graphics were generated for the updates in other jobs.
Map 3D took a long time to update or delete features from templates in large, job-enabled databases.
Crash when creating the job perimeter by selecting a complex polygon from the area.
Stretching a vertex caused other vertices to be moved together.
Stretching vertex for arcs had an offset.
Rotated raster files were displayed in a filled orthogonal frame.
Bulk Copy would fail if the source layer contains a join.
Geolocation would be shifted when the drawing was reopened in AutoCAD Map 3D.
ANSI31 hatch was exported with wrong scaling and orientation during MAPTOACAD.
During MAPTOACAD operation, exported symbols with feature labels didn't get replaced with DWT blocks, so they had no global width and a different block naming.
MAPSYMBOLIMPORTEXPORT didn't replace the symbols correctly.
In Industry Model Forms, for ComboBox control with multiple detail tables, Detail SortOrder setting didn't work with other attributes except FID.
DETAILFILTER statement of Combo Box control was composed differently in Form and Designer preview.
AutoCAD Map 3D created the wrong result with intersection for some data when performing overlay analysis.
Split Cable operation associated the wrong devices to split cables.
When you digitize multiple points at the same location, whether an internal structure is automatically generated now depends on the field value that you set in the database table.
Note: To turn on this function, access the TB_info table, add one record, set param: to ALLOW_DUPLICATE_DEVICE, and Value_numer to 1. To turn off this function, set Value_numer to 0.
AutoCAD Map 3D encountered an SSL connect error when connecting to FEMA WMS service.
Some attribute values from WFS service were not displayed correctly in AutoCAD Map 3D.
Stylized FDO data disappeared in a viewport that was rotated.
(Autodesk Expert Elite Team)
#2 Mon 15 April 2019 11:24
Patrice
Re: ACAD MAP 201X-202X - Tech Infos Divers
Hello
Sujet mis a jour avec les Infos 2020 & 2021 & 2022 & 2023 ...
La Sante, GeoBye, Pat
