#1 Wed 11 December 2013 17:43
sampi
QGIS 2.0.1 : Lambert II etendu/erreur: failed to load datum shift file
je ne suis pas très aguéri avec QGIS et j'ai un souci lorsque je veux définir les propriétés de mon projet en "Lambert II étendu"
j'ai une fenetre exception qui s'ouvre avec le texte suivant:
Poursuivre la transformation de
(-0.028574, -0.017453)
(-0.020410, -0.017453)
(-0.012246, -0.017453)
(-0.004082, -0.017453)
(0.004082, -0.017453)
(0.012246, -0.017453)
(0.020410, -0.017453)
(0.028574, -0.017453)
(-0.028574, -0.012467)
(-0.020410, -0.012467)
(-0.012246, -0.012467)
(-0.004082, -0.012467)
(0.004082, -0.012467)
(0.012246, -0.012467)
(0.020410, -0.012467)
(0.028574, -0.012467)
(-0.028574, -0.007480)
(-0.020410, -0.007480)
(-0.012246, -0.007480)
(-0.004082, -0.007480)
(0.004082, -0.007480)
(0.012246, -0.007480)
(0.020410, -0.007480)
(0.028574, -0.007480)
(-0.028574, -0.002493)
(-0.020410, -0.002493)
(-0.012246, -0.002493)
(-0.004082, -0.002493)
(0.004082, -0.002493)
(0.012246, -0.002493)
(0.020410, -0.002493)
(0.028574, -0.002493)
(-0.028574, 0.002493)
(-0.020410, 0.002493)
(-0.012246, 0.002493)
(-0.004082, 0.002493)
(0.004082, 0.002493)
(0.012246, 0.002493)
(0.020410, 0.002493)
(0.028574, 0.002493)
(-0.028574, 0.007480)
(-0.020410, 0.007480)
(-0.012246, 0.007480)
(-0.004082, 0.007480)
(0.004082, 0.007480)
(0.012246, 0.007480)
(0.020410, 0.007480)
(0.028574, 0.007480)
(-0.028574, 0.012467)
(-0.020410, 0.012467)
(-0.012246, 0.012467)
(-0.004082, 0.012467)
(0.004082, 0.012467)
(0.012246, 0.012467)
(0.020410, 0.012467)
(0.028574, 0.012467)
(-0.028574, 0.017453)
(-0.020410, 0.017453)
(-0.012246, 0.017453)
(-0.004082, 0.017453)
(0.004082, 0.017453)
(0.012246, 0.017453)
(0.020410, 0.017453)
(0.028574, 0.017453)
PROJ.4: +proj=longlat +datum=WGS84 +no_defs +to +proj=lcc +lat_1=46.8 +lat_0=46.8 +lon_0=0 +k_0=0.99987742 +x_0=600000 +y_0=2200000 +a=6378249.2 +b=6356514.999978254 +nadgrids=ntf_r93.gsb,null +pm=2.337229167 +units=m +no_defs
Erreur: failed to load datum shift file
Quelqu'un aurait il une solution à me donner
d'avance merci
Sampi
#2 Fri 17 January 2014 12:07
krakatoe
Re: QGIS 2.0.1 : Lambert II etendu/erreur: failed to load datum shift file
Bonjour, j'ai exactement le même problème, qui n'apparait qu'avec le lambert 2 étendu. Même souci lorsque je paramètre la reprojection à la volée sur se système.
Idées bienvenues.
EDIT : voici un lien vers un site qui me semble traiter du problème. C'est un peu au delà de mes compétences cependant, en espérant qu'un vulgarisateur pourra nous éclairer.
https://hub.qgis.org/issues/7941
Dernière modification par krakatoe (Fri 17 January 2014 12:17)
#3 Fri 17 January 2014 14:04
RenaudL
L'insertion professionnelle par la géomatique
Pour le Lambert II étendu il est préférable d'utiliser le SCR Lambert zone II (code EPSG 27572) (et non le Lambert II étendu avec un ID IGNF).
Si ce n'est pas celui que vous utilisez je vous conseille de le faire?
#4 Fri 17 January 2014 15:05
Didier Vanden Berghe
Salut
Malheureusement ceci est un bug propre à la version 64 bits.
La version 32 bits n'a pas à priori pas ce problème.
#5 Fri 17 January 2014 16:03
krakatoe
Bonjour effectivement je confirme être sous windows 64 bits.
J'ai contourné le problème en convertissant mes données avec le bon vieux Circé de l'IGN, et un coup de tableur pour importer sous qgis.
Également, je n'en suis pas sûr, il me semble néanmoins avoir essayé avec le L II de l'IGN, qui n'avait pas d'EPSG. Peut-être que la solution d'utiliser l'EPSG 27572 marche mais je ne l'ai pas testée. J'essaierai la prochaine fois.
Merci pour votre retour.
#6 Fri 17 January 2014 20:43
Yves
Lieu: Aix-les-Bains
Renaud_IDGEO a écrit:
Pourquoi est ce préférable ?
#7 Thu 13 February 2014 12:50
morgane88
Ayant eu un problème similaire: impossibilité de reprojeter en Lambert 93 une couche initialement en Lambert II étendu (également avec une version 64bits), je précise juste que l'utilisation du Lambert zone II EPSG 27572 (proposée par Renaud_IDGEO) permet de pallier ce problème.
Dernière modification par morgane88 (Thu 13 February 2014 12:51)
#8 Fri 14 February 2014 14:38
jcr83
Peut-être, mais avec une perte de précision, puisqu'on utilise une transformation à 7 paramètres au lieu d'une transformation à grille.
