#1 Tue 08 October 2002 12:33
Stefan Majtan
Annonce: Grid Analyser v. 3.3
Dear users and listers.
I would like inform all of you that Grid Analyser v. 3.3 released. There were did a big changes in
core code in order to improve stability.
And what is new? Here is a simple list of main improves.
- solved the problem with decimal separator. Now supported as . as , .
- Improved Contour module - automatic filling contour.
- Improved Info module - calculation statistic for given class(es).
- definitely solved the problems with iterations with others MapInfo's windows.
- Improved Import module. From this version support all MapInfo's projections.
- fixed bug of Color module. (Value's color file).
Mainly, improves are based on yours suggestions and comments. I would like to thank especially to
Mr. Nadal for his suggestions and comment on GA homepage a ask of all you to write your suggestions
and comment. It will help not only you but also another users of GA.
Recently my time is very limited therefore I do not update the help file. If somebody want to help
from this point of view it will be welcome. If somebody has the problem with operation of GA,
contact me immediately.
Finally, I would like wish a happy time with Grid Analyser. The program can be downloaded from GA
homepage (gridanalyser.dyndns.org).
Thanks all who's using Grid Analyser.
Best regrads Stefan Majtan
