#1 Tue 09 March 2010 13:32
nicolas.leclerc
[Mapserver/Postgis]
j'essaie d'afficher un mapfile avec phpmapscript. Ma requête tourne nickel sous postgis.
je n'arrive pas à saisir d'où vient mon erreur.
voici le message
Warning: [MapServer Error]: msDrawMap(): Failed to draw layer named 'Boucheries charcuteries traiteurs3'. in C:\ms4w\Apache\htdocs\test.php on line 5 Warning: [MapServer Error]: msPostGISLayerGetItems(): Error (ERREUR: erreur de syntaxe sur ou près de « where » LINE 34: ) where false limit 0 ^ ) executing SQL: select * from cce,equip_point WHERE ( id_cce in ( SELECT id_cce from geo where id_secteur=52 ) ) AND id_cce in ( SELECT id_cce from siret where ( date_fin is null AND ( id_t2=3 ) ) ) AND ( ( distance(cce.the_geom,equip_point.the_geom)<300 AND ( id_point in ( SELECT id_geom from equip where id_teq=2 ) ) ) ) where false limit 0 in C:\ms4w\Apache\htdocs\test.php on line 5 Fatal error: Call to a member function saveWebImage() on a non-object in C:\ms4w\Apache\htdocs\test.php on line 7
mon mapfile
MAP
  NAME "Cartographie des commerces"
  STATUS ON
  EXTENT 435697.659999996 196835.210000001 444937.859999999 206913.719999999
  SIZE 800 800
  FONTSET "c:/ms4w/Apache/htdocs/fonts.list"
  UNITS METERS
  IMAGECOLOR 207 218 235
  IMAGETYPE png
  OUTPUTFORMAT
      NAME png
      DRIVER "agg/PNG"
      MIMETYPE "image/png"
      IMAGEMODE RGBA
      EXTENSION "png"
  END
  WEB
      #le chemin IMAGEPATH doit être saisi en dur...
      IMAGEPATH "c:/ms4w/Apache/htdocs/tmp/"
      IMAGEURL "/tmp/"
      MINSCALE 250
  END
  LEGEND
        STATUS ON
        IMAGECOLOR 255 243 211
        KEYSIZE 15 15
        KEYSPACING 5 5
        LABEL
            TYPE TRUETYPE
              FONT "arial"
              SIZE 8
              COLOR 0 0 0
              PARTIALS TRUE
        END
  END
  SCALEBAR
      STATUS EMBED
        COLOR 0 0 0
        TRANSPARENT OFF
        UNITS KILOMETERS
        INTERVALS 2
        SIZE 120 2
        STYLE 1
        POSITION LL
        LABEL
            TYPE BITMAP
              SIZE SMALL
              OFFSET 0 0
              COLOR 0 0 0
              PARTIALS FALSE
        END
  END
  LAYER
      NAME "Boucheries charcuteries traiteurs3"
       STATUS ON
       CONNECTIONTYPE POSTGIS
       CONNECTION "user=postgres password=eclipse dbname=ccih host=127.0.0.1"
      DATA "SELECT cce.the_geom from cce,equip_point
            WHERE
                    id_cce in
                AND
                id_cce in
                AND
                        AND
                            id_point in
                         id_teq=2
                ) using unique gid"
      PROJECTION
          "init=epsg:27561"
      END # Projection
      DUMP TRUE
      LABELITEM "affichage"
      TYPE POINT
          CLASSGROUP "Boucheries charcuteries traiteurs3"
          CLASS
              LABEL
                TYPE TRUETYPE
                FONT arial
                SIZE 9
                BUFFER 5
                FORCE FALSE
                PARTIALS TRUE
                POSITION AUTO
            BACKGROUNDCOLOR 225 225 225
              END
             MINSCALE 50000
             MAXSCALE 1000000
             STYLE
                     SYMBOL 'c:/ms4w/Apache/htdocs/symbols/3_10px.png'
             END
           END
          CLASS
              LABEL
                TYPE TRUETYPE
                FONT arial
                SIZE 9
                BUFFER 5
                FORCE FALSE
                PARTIALS TRUE
                POSITION AUTO
              END
             MINSCALE 4000
             MAXSCALE 15000
             STYLE
                     SYMBOL 'c:/ms4w/Apache/htdocs/symbols/3_30px.png'
             END
           END
          CLASS
              LABEL
                TYPE TRUETYPE
                FONT arial
                SIZE 9
                BUFFER 5
                FORCE FALSE
                PARTIALS TRUE
                POSITION AUTO
              END
             MINSCALE 15000
             MAXSCALE 50000
             STYLE
                     SYMBOL 'c:/ms4w/Apache/htdocs/symbols/3_20px.png'
             END
           END
          CLASS
              LABEL
                TYPE TRUETYPE
                FONT arial
                SIZE 9
                BUFFER 5
                FORCE FALSE
                PARTIALS TRUE
                POSITION AUTO
              END
        MINSCALE 500
            MAXSCALE 4000
            STYLE
                     SYMBOL 'c:/ms4w/Apache/htdocs/symbols/3_64px.png'
             END
       END
  END
END
si quelqu'un à une idée je suis preneur !
#2 Sun 14 March 2010 21:24
Yves
Lieu: Aix-les-Bains
Re: [Mapserver/Postgis]
Regarde la doc de MapServer pour le paramètr DATA :
DATA "the_geom FROM (SELECT cce.the_geom from cce,equip_point
            WHERE
                    id_cce in
                AND
                id_cce in
                AND
                        AND
                            id_point in
                         id_teq=2
           ) as foo using unique gid"
#3 Thu 18 March 2010 16:44
nicolas.leclerc
mon erreur venait bien de là.
c'est résolu
Merci beaucoup, encore une fois...
