#1 Sat 17 December 2011 09:18
- Patrice
- Moderateur
labs.autodesk.com : MAP 2012 Standard - Project PARSEC
Hello
Les zozos des Labs d'Autodesk ont sorti un nouveau truc ...
Je n'ai pas encore telecharge ni teste ? Si qq'un a du courage un petit retour sera le bienvenu !
http://labs.autodesk.com/utilities/parsec/
Cet outil ne fonctionne qu'avec la version Standard de MAP 3D 2012
donc avec les modeles metiers en SQLite dans le fichier DWG ...
GeoBye, Pat
--- Overview ---
The free* technology preview of Project Parsec for AutoCAD Map 3D 2012 software provides functionality that enables
users to import and map GIS geometries and attributes to AutoCAD Map 3D industry models* from SDF, SQLite, and Esri SHP
and geodatabase files, as well as Microsoft SQL Server and Oracle databases. By integrating CAD and GIS data in an
industry-specific data model (for example, electric, water, wastewater, or gas), Map 3D users can:
- More easily create intelligent preliminary designs using industry-specific content and rules
- Perform analysis (for example, network tracing and attribute-driven thematic mapping) to help plan for service disruptions
- Help identify infrastructure that requires replacement or maintenance
- Report on existing infrastructure assets for stakeholders or regulatory agencies
****** Project Parsec does not work with AutoCAD Map 3D Enterprise 2012 software.
--- Latest Update ---
The latest update adds French, Italian, German, and Spanish language installers to accompany the English ones.
The installers come in 32-bit and 64-bit flavors.
--- Availability ---
Project Parsec is currently available in English. Support for additional languages (i.e., French, Italian, German, and
Spanish) is planned. The English language version can be installed on any language version of AutoCAD Map 3D 2012
software. Once installed, a new Convert to Industry Model icon will appear in the AutoCAD Map 3D user interface on the
Insert tab. This technology preview will operate until December 31, 2012.
(Autodesk Expert Elite Team)
