#1 Wed 06 July 2011 10:05
bill08
QGIS 1.6 : Table manager ininstallable --> no module named tablemanage
Bonjour à tous et à toutes,
Je souhaite modifier ma table attributaire et je veux donc installer table manager.
donc je fais "extension" -->"installateur d'extensions python"
ensuite je cherche table manager dans ma liste et je clic sur installer. L'installation démarre et la une fenètre s'ouvre avec :
Impossible de charger l'extension 'tablemanager' depuis ['D:/NOUVEA~4/QUANTU~1/apps/qgis/./python', 'C:/Users/Clément/.qgis/python', 'C:/Users/Clément/.qgis/python/plugins', 'D:/NOUVEA~4/QUANTU~1/apps/qgis/./python/plugins', 'D:\NOUVEA~4\QUANTU~1\apps\gdal-17\pymod', 'D:\', 'D:\NOUVEA~4\QUANTU~1\bin\python25.zip', 'D:\NOUVEA~4\QUANTU~1\apps\Python25\DLLs', 'D:\NOUVEA~4\QUANTU~1\apps\Python25\lib', 'D:\NOUVEA~4\QUANTU~1\apps\Python25\lib\plat-win', 'D:\NOUVEA~4\QUANTU~1\apps\Python25\lib\lib-tk', 'D:\NOUVEA~4\QUANTU~1\apps\qgis\bin', 'D:\NOUVEA~4\QUANTU~1\apps\Python25', 'D:\NOUVEA~4\QUANTU~1\apps\Python25\lib\site-packages', 'D:\NOUVEA~4\QUANTU~1\apps\Python25\lib\site-packages\win32', 'D:\NOUVEA~4\QUANTU~1\apps\Python25\lib\site-packages\win32\lib', 'D:\NOUVEA~4\QUANTU~1\apps\Python25\lib\site-packages\Pythonwin', 'D:\NOUVEA~4\QUANTU~1\apps\Python25\lib\site-packages\wx-2.8-msw-unicode', 'D:\NOUVEA~4\QUANTU~1\apps\qgis\python\plugins\fTools\tools', 'D:']
  File "D:/NOUVEA~4/QUANTU~1/apps/qgis/./python\qgis\utils.py", line 117, in loadPlugin
    __import__(packageName)
  File "D:/NOUVEA~4/QUANTU~1/apps/qgis/./python\qgis\utils.py", line 279, in _import
    mod = _builtin_import(name, globals, locals, fromlist, level)
ImportError: No module named tablemanager
Version de Python :
2.5.2 (r252:60911, Feb 21 2008, 13:11:45) [MSC v.1310 32 bit (Intel)]
Version de QGIS :
1.6.0-Capiapo Capiapo, exported
Chemin vers Python : ['D:/NOUVEA~4/QUANTU~1/apps/qgis/./python', 'C:/Users/Cl\xc3\xa9ment/.qgis/python', 'C:/Users/Cl\xc3\xa9ment/.qgis/python/plugins', 'D:/NOUVEA~4/QUANTU~1/apps/qgis/./python/plugins', 'D:\\NOUVEA~4\\QUANTU~1\\apps\\gdal-17\\pymod', 'D:\\', 'D:\\NOUVEA~4\\QUANTU~1\\bin\\python25.zip', 'D:\\NOUVEA~4\\QUANTU~1\\apps\\Python25\\DLLs', 'D:\\NOUVEA~4\\QUANTU~1\\apps\\Python25\\lib', 'D:\\NOUVEA~4\\QUANTU~1\\apps\\Python25\\lib\\plat-win', 'D:\\NOUVEA~4\\QUANTU~1\\apps\\Python25\\lib\\lib-tk', 'D:\\NOUVEA~4\\QUANTU~1\\apps\\qgis\\bin', 'D:\\NOUVEA~4\\QUANTU~1\\apps\\Python25', 'D:\\NOUVEA~4\\QUANTU~1\\apps\\Python25\\lib\\site-packages', 'D:\\NOUVEA~4\\QUANTU~1\\apps\\Python25\\lib\\site-packages\\win32', 'D:\\NOUVEA~4\\QUANTU~1\\apps\\Python25\\lib\\site-packages\\win32\\lib', 'D:\\NOUVEA~4\\QUANTU~1\\apps\\Python25\\lib\\site-packages\\Pythonwin', 'D:\\NOUVEA~4\\QUANTU~1\\apps\\Python25\\lib\\site-packages\\wx-2.8-msw-unicode', 'D:\\NOUVEA~4\\QUANTU~1\\apps\\qgis\\python\\plugins\\fTools\\tools', 'D:']
du coup je fais OK et ca me propose de désinstaller et ca me dis que l'extension est corrompue et : No module named table manager
si je ne désinstalle pas, dans la liste d'extensions le statut est "invalide" la version est "?"  et la description "cette extension est corrompue"
que puis-je faire ?
j'ai réessayé plusieurs fois, éteint rallumé le pc rien ne change sad
merci par avance
edit : j'ai essayé une autre extension et ca ne marche pas non plus donc ca doit être global
je sais pas si ca peut être la raison, mais j'ai installé qgis sous mon disque dur D (et pas le C)
Dernière modification par bill08 (Wed 06 July 2011 10:51)
#2 Thu 21 July 2011 15:58
turbines
Re: QGIS 1.6 : Table manager ininstallable --> no module named tablemanage
Je rencontre exactement le même problème, avez-vous une solution?
#3 Thu 21 July 2011 16:43
bill08
salut,
je n'ai pas trouvé de solution à mon problème mais ceci vient probablement du lieu ou j'ai installé Qgis. Je m'explique
j'ai installé Qgis sous mon disque dur D (celui qui ne contient pas tout le système windows (système 32 et compagnie)) je pense que ca provient de ca.
J'ai installé sur un autre pc qgis (1.7 car 1.6 n'existait plus depuis 1 semaine) et je l'ai installé comme on installe "logiquement" un logiciel sous le lecteur C et la ca marche.
Donc je pense que ca provient de ton pc (comme du mien)
#4 Wed 27 July 2011 16:00
turbines
merci je vais essayer avec cette méthode...
