#1 Fri 15 April 2011 10:48
Soucré
creation d'un menu pour ajouter des champs
comment faire pour ajouter des champs a une tables existant avec un Control PopupMenu .
ici un début de code
Include "MapBasic.def"
Include "Menu.def"
Include "Icons.def"
Declare Sub Main
Declare Sub choix
Dim ApplicationPath, champs(20), str,toto as String
Dim i As SmallInt
dim Valeur1,Valeur2,Valeur3 as alias
Dim tata as integer
Sub Main
dialog
  title "Ajouter champs"
  control statictext position 150,30 width 30 title "CHOIX "
  Control StaticText position 10,30 title "CONSOMMATION" Control EditText position 80,30 width 60 id 7
  Control PopupMenu Title  "Aucun;ALIMENTATION;alcoolise;nonalcool;HABILLEMENT;JOUETS;CHAUSSURES;Ameubledeco;ENTRETIEN;bricojardin;ELECTROMENAGER;AVI;SPORT;loisirsculture;autres"
  id 100 value 1 into tata Position 185,30 width 55 Height 40 calling choix
  control statictext position 150,60 width 30 title "CHOIX "
  Control StaticText position 10,60 title "CONSOMMATION" Control EditText position 80,60 width 60 id 8
  id 100 value 1 into tata Position 185,60 width 55 Height 40 calling choix
  Control StaticText position 150,90 width 30 title "CHOIX"
  Control StaticText position 10,90 title "CONSOMMATION" Control EditText position 80,90 width 60 id 9
  id 100 value 1 into tata Position 185,90 width 55 Height 40 calling choix
  control OKButton Position 100, 180 Width 50 Title "OK"
  control CancelButton Position 30, 180 Width 50 Title "Annuler"
if commandinfo(cmd_info_dlg_ok) then
end if
   SET PROGRESSBARS ON
End Sub
Sub choix
toto=readcontrolvalue(100)
        if toto="1" then alter control 7 value "AUCUN"
    elseif toto="2" then alter control 7 value "ALIMENTATION"
    elseif toto="3" then alter control 7 value "alcoolise"
    elseif toto="4" then alter control 7 value "nonalcool"
    'elseif toto="5" then alter control 7 value "HABILLEMENT"
    'elseif toto="6" then alter control 7 value "JOUETS"
    'elseif toto="7" then alter control 7 value "CHAUSSURES"
    'elseif toto="8" then alter control 7 value "Ameubledeco"
    'elseif toto="9" then alter control 7 value "ENTRETIEN"
    'elseif toto="10" then alter control 7 value "bricojardin"
    'elseif toto="11" then alter control 7 value "ELECTROMENAGER"
    'elseif toto="12" then alter control 7 value "AVI"
    'elseif toto="13" then alter control 7 value "SPORT"
    'elseif toto="14" then alter control 7 value "loisirsculture"
    'elseif toto="15" then alter control 7 value "autres"
   'elseif toto="16" then alter control 7 value "autres2"
   'elseif toto="17" then alter control 7 value "autres3"
end if
  Alter Table "ma_table" ( add value  Integer ) Interactive
  'Alter Table "ma_table" ( add value  Integer ) Interactive
end sub
#2 Fri 15 April 2011 14:47
jean94
Re: creation d'un menu pour ajouter des champs
Remplace "Value" dans la ligne ci-dessous par le nom de la colonne
Par
Alter Table "ma_table" ( add ma_colonne Integer ) Interactive
ma_colonne pouvant être remplacée par une variable de type string
JF
Dernière modification par jean94 (Fri 15 April 2011 14:47)
#3 Mon 18 April 2011 12:16
Soucré
il me remplis le même choix partout   et le message suivant  (remplissage_tab2.mb :112) le champs alimentation existe déja.
Include "Menu.def"
Include "Icons.def"
Declare Sub Main
Declare Sub choix
Dim i As SmallInt
Dim tata as integer
Sub Main
dialog
end if
   SET PROGRESSBARS ON
End Sub
Sub choix
end if
if toto="1" then alter control 8  value "AUCUN"
    elseif toto="2" then alter control 8  value "ALIMENTATION"
   elseif toto="3" then alter control 8  value "alcoolise"
       elseif toto="4" then alter control 8  value "nonalcool"
   elseif toto="5" then alter control 8 value "HABILLEMENT"
    elseif toto="6" then alter control 8 value "JOUETS"
    elseif toto="7" then alter control 8 value "CHAUSSURES"
    elseif toto="8" then alter control 8 value "Ameubledeco"
    elseif toto="9" then alter control 8 value "ENTRETIEN"
    elseif toto="10" then alter control 8 value "bricojardin"
    elseif toto="11" then alter control 8 value "ELECTROMENAGER"
    elseif toto="12" then alter control 8 value "AVI"
    elseif toto="13" then alter control 8 value "SPORT"
    elseif toto="14" then alter control 8 value "loisirsculture"
    elseif toto="15" then alter control 8 value "autres"
   elseif toto="16" then alter control 8 value "autres2"
   elseif toto="17" then alter control 8 value "autres3"
end if
if toto="1" then alter control 9 value "AUCUN"
    elseif toto="2" then alter control 9 value "ALIMENTATION"
   elseif toto="3" then alter control 9 value "alcoolise"
       elseif toto="4" then alter control 9 value "nonalcool"
   elseif toto="5" then alter control 9 value "HABILLEMENT"
    elseif toto="6" then alter control 9 value "JOUETS"
    elseif toto="7" then alter control 9 value "CHAUSSURES"
    elseif toto="8" then alter control 9 value "Ameubledeco"
    elseif toto="9" then alter control 9 value "ENTRETIEN"
    elseif toto="10" then alter control 9 value "bricojardin"
    elseif toto="11" then alter control 9 value "ELECTROMENAGER"
    elseif toto="12" then alter control 9 value "AVI"
    elseif toto="13" then alter control 9 value "SPORT"
    elseif toto="14" then alter control 9 value "loisirsculture"
    elseif toto="15" then alter control 9 value "autres"
   elseif toto="16" then alter control 9 value "autres2"
   elseif toto="17" then alter control 9 value "autres3"
end if
' ma_table= selto
    Alter Table "ma_table" ( add ALIMENTATION  Integer ) Interactive
    Alter Table "ma_table" ( add alcoolise Integer ) Interactive
    Alter Table "ma_table" ( add  nonalcool Integer ) Interactive
    Alter Table "ma_table" ( add HABILLEMENT Integer ) Interactive
    Alter Table "ma_table" ( add  JOUETS Integer ) Interactive
    Alter Table "ma_table" ( add  CHAUSSURES Integer ) Interactive
    Alter Table "ma_table" ( add  Ameubledeco Integer ) Interactive
    Alter Table "ma_table" ( add  ENTRETIEN Integer ) Interactive
    Alter Table "ma_table" ( add  bricojardin Integer ) Interactive
    Alter Table "ma_table" ( add  ELECTROMENAGER Integer ) Interactive
    Alter Table "ma_table" ( add  AVI Integer ) Interactive
    Alter Table "ma_table" ( add  SPORT Integer ) Interactive
    Alter Table "ma_table" ( add  loisirsculture Integer ) Interactive
    Alter Table "ma_table" ( add  autres Integer ) Interactive
    Alter Table "ma_table" ( add  autres2 Integer ) Interactive
    Alter Table "ma_table" ( add  autres3 Integer ) Interactive
end sub
#4 Mon 18 April 2011 14:08
jean94
As-tu vérifier si tu avait déja le champ alimentation!
STP quand tu copies ton code sur se forum utilise les balises code.
JF
#5 Thu 28 April 2011 11:15
Soucré
merci ça marche
