#1 Wed 30 March 2011 14:19
alexta
Problème Bounds Is null Mapserver Openlayers
voilà j'ai un problème que je n'arrive pas à résoudre :
sur firebug ça me met bounds is null
<html>
    <head>
    <style>
    #panel {
        right: 0px;
        height: 30px;
        width: 200px;
    #panel div {
        float: left;
        margin: 5px;
  </style>
    <title>OpenLayers Example</title>
    <script src="http://openlayers.org/api/OpenLayers.js"></script>
    <div id="mouseposition"></div>
    <div id="panel"></div>
    </head>
    <body>
      <div style="width:100%; height:100%" id="map"></div>
      <script defer="defer" type="text/javascript">
        var map = new OpenLayers.Map('map');
        map.addControl (new OpenLayers.Control.MousePosition({
        div: document.getElementById("mouseposition")
        var layer = new OpenLayers.Layer.WFS(
            "wfs", "http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/test/MapFile/indonesie_pop.map&",
            {typename: 'Admin_Indonesie'},
            { extractAttributes: true}
        map.addLayer(layer);
        var overview = new OpenLayers.Control.OverviewMap();
        map.addControl(overview);
        var panel = new OpenLayers.Control.Panel({
        div: document.getElementById("panel")
          var history = new OpenLayers.Control.NavigationHistory();
          map.addControl(history);
          panel.addControls([history.next, history.previous]);
        map.addControl(panel)
        map.zoomToMaxExtent();
      </script>
</body>
</html>
et le mapfile :
MAP
        SIZE 1000 500
        EXTENT 94.0000 -9.0048 131.000 4
          UNITS METERS
          IMAGECOLOR 255 255 255
          SHAPEPATH "C:/ms4w/Apache/htdocs/test/MapFile/"
      WEB
        IMAGEPATH "C:/ms4w/Apache/htdocs/test/MapFile/MapFile/tmp"
        IMAGEURL "tmp/"
        METADATA
            "wfs_title"            "dep"
            "wfs_onlineresource"   "http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/test/MapFile/indonesie_pop.map"  ## Recommended
            "wfs_srs"              "epsg:4326"  ## Recommended
        END
      END
    OUTPUTFORMAT
        NAME png
        DRIVER "GD/PNG"
        MIMETYPE "image/png"
        IMAGEMODE PC256
        EXTENSION "png"
    END
#  Layer Administratif
      LAYER
        NAME Admin_Indonesie
        STATUS ON
        CONNECTIONTYPE OGR
        CONNECTION "C:/ms4w/Apache/htdocs/test/MapFile/indonesie_surface.tab"
        METADATA
            ### WFS
            "wfs_title"            "departement"
            "gml_featureid"     "NAME"
            "gml_include_items" "all"
        END
        PROJECTION
            "init=epsg:4326" ##recommended
        END
        DUMP TRUE
        TYPE LINE
            CLASS
                  STYLE
                    COLOR 0 0 0
                     OUTLINECOLOR 255 255 255
                  END
            END
      END
END
Si quelqu'un pourrait m'aider ça serait sympa ! Merci d'avance smile
Dernière modification par alexta (Wed 30 March 2011 14:23)
