#1 Thu 20 January 2011 12:05
LASGOUZES
Fme 2011
Fme 2011 a été mis en ligne depuis hier information Dale Lutz, Safe Software (FME)
FME 2011 Highlights:
Point Cloud Support: Read, write and transform massive point cloud datasets in industry standard formats including LAS, Pointools POD, and XYZ ASCII.
Usability Enhancements: Build and maintain workspaces at lightning speed with the revamped SchemaMapper, Templates, more Tester predicates, new SQL transformers, and much more.
Inline Inspection: Inspect the current state of your data as it passes from one transformer to the next with FME's innovative workspace debugging capabilities.
XML Improvements: Spend less time battling XML thanks to new XMLTemplater, validation, styling, and cataloguing capabilities.
Scheduling: Set workspaces to run whenever you want with the new scheduling tool in FME Server.
Cloud Data Formats: Read and write cloud data, with new support for Windows Azure, SQL Azure, OGDI, and Google Spreadsheets.
