#1 Thu 13 January 2011 10:57
Pierre
DesCartesPourUnMondeMeilleur
Calage Raster : Erreur en lecture pour des jpg
Aloha
J'obtiens ce message d'erreur lorsque j'ouvre un jpg dans le viewer et visiblement le calage n'est pas conservé :
The OGC definition of the FME coordinate system 'IGN-RGF93' is 'CoordSys Earth Projection 3, 33, "m", 3, 46.5, 44, 49, 700000, 6600000'
JPEG reader: Successfully read TAB file 'Y:\DIVERS\Brouillon\EM\planford_72.TAB'
JPEG reader: The source dataset contains GCPs but no projection information. If GCPs are applied the coordinates will be converted but no coordinate system will be set
Resampler: Resampling raster from a cell size of (1, 1) to a cell size of (14.1430231365946, 14.1430231365946)
Resampler: This operation does not preserve Ground Control Points (GCPs).  All existing GCPs will be discarded
Resampler: Recalculating raster dimensions from '4032' row(s) and '4166' column(s) to '285' row(s) and '295' column(s)
Using source sampling
Mon .TAB est défini comme suit :
!table
!version 300
!charset WindowsLatin1
Definition Table
  File "planford_72.jpg"
  Type "RASTER"
  (775658.90000000002,6906910.2999999998) (2099,1811) Label "Pt 1",
  (775294.09999999998,6906696.2999999998) (1889,1943) Label "Pt 2",
  (774793.19999999995,6906647.2000000002) (1618,1982) Label "Pt 3",
  (775638.90000000002,6905721) (2129,2466) Label "Pt 4",
  (774715.90000000002,6907773.2000000002) (1549,1358) Label "Pt 5"
  Units "m"
Quelqu'un a-t'il une idée sur la source du problème ?
D'avance, merci,
