#1 Fri 05 November 2010 11:53
soussou126
[mapfish]afficher une liste des noeuds de ma trajectoire
Bonjour touts le monde,
je travaille avec mapfish 1.2 et j'ai une fonctionnalité qui me permet d'afficher le trajet entre de point de ma map (routing) que j'ai piqué de la documentations officiel de pgrouting http://pgrouting.postlbs.org/wiki/Works … G2008/ch03 et qui marche très bien
    var selectPointControl;
    function selectPoint(event, element) {
        if (selectPointControl.active) {
            selectPointControl.input = null;
            selectPointControl.deactivate();
            Ext.get(element).removeClass('x-form-trigger-click');
        } else {
            selectPointControl.input = this;
            selectPointControl.activate();
            Ext.get(element).addClass('x-form-trigger-click');
    function pointSelected(feature) {
        if (feature) {
            if (this.input && !feature.input) {
                for (var i = 0; i < feature.layer.features.length; i++) {
                    var f = feature.layer.features[i];
                    if (f.input == this.input) {
                        feature.layer.removeFeatures([f]);
                        break;
                feature.input = this.input;
                // set the feature style
                if (feature.input.name == 'source') {
                    feature.style = mapfish.Routing.firstPointStyle;
                } else if (feature.input.name == 'target') {
                    feature.style = mapfish.Routing.lastPointStyle;
                feature.layer.redraw();
            var lonlat = new OpenLayers.LonLat(feature.geometry.x,
                    feature.geometry.y);
            lonlat.transform(this.map.getProjectionObject(),
                    this.displayProjection);
            var point = new OpenLayers.Geometry.Point(lonlat.lon, lonlat.lat);
            feature.input.setValue(point.toString());
            Ext.get(feature.input.trigger).removeClass('x-form-trigger-click');
    var routing = new mapfish.Routing('routes/routing', map, {
                fetchRoute : function(button, event) {
                    var form = button.ownerCt.getForm();
                    var feat;
                    if (form.isValid()) {
                        feat = mapfish.Routing.prototype.fetchRoute.call(this, form
                                        .getValues());
                    this.parser = new OpenLayers.Format.GeoJSON({
                                internalProjection : this.map.projection,
                                externalProjection : this.map.displayProjection
    var selectPointLayer = new OpenLayers.Layer.Vector("point select", {
                displayInLayerSwitcher : false
    map.addLayer(selectPointLayer);
    selectPointControl = new OpenLayers.Control.DrawFeature(selectPointLayer,
            OpenLayers.Handler.Point, {
                featureAdded : pointSelected
    map.addControl(selectPointControl);
    var dragFeature = new OpenLayers.Control.DragFeature(selectPointLayer, {
                onComplete : pointSelected
    map.addControl(dragFeature);
    dragFeature.activate();
    var routingPanel = {
        title : 'Routing',
        xtype : 'form',
        defaultType : 'combo',
        defaults : {
            width : 170,
            listWidth : 160,
            allowBlank : false,
            onTriggerClick : selectPoint,
            triggerClass : 'x-form-search-trigger'
        items : [{
                    fieldLabel : 'Departure',
                    fieldLabel : 'Arrival',
        buttons : [{
                    text : 'Show Itinerary',
                    handler : routing.fetchRoute,
                    scope : routing
je veux ajouter une liste des différents nœuds par le quel passe mon trajet, mais je ne sais pas comment mis prendre!!
il y a t'il quelqu'un qui peut m'aider!
merci
