#1 Thu 26 November 2020 22:47
- othx
QGIS/Module SCP: reflectance de surface
Je souhaite transformer des rasters Landsat en réflectance de surface.
Pour cela, j'utilise le module SCP.
Mais j'obtiens cette erreur ... Qu'en pensez-vous ?
Une erreur est survenue lors de l'éxécution du code Python:
EOFError
File "/Users/olivier/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/SemiAutomaticClassificationPlugin/maininterface/landsatTab.py", line 640, in performLandsatCorrection
self.landsat(cfg.ui.label_26.text(), o)
File "/Users/olivier/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/SemiAutomaticClassificationPlugin/maininterface/landsatTab.py", line 331, in landsat
LDNmList = cfg.utls.findDNmin(tPMDN, NoData)
File "/Users/olivier/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/SemiAutomaticClassificationPlugin/core/utils.py", line 2047, in findDNmin
o = cfg.utls.multiProcessRaster(rasterPath = inputRaster, functionBand = 'No', functionRaster = cfg.utls.rasterUniqueValuesWithSum, nodataValue = noDataVal, progressMessage = cfg.QtWidgetsSCP.QApplication.translate('semiautomaticclassificationplugin', 'DOS1 calculation'), deleteArray = 'No', parallel = cfg.parallelArray)
File "/Users/olivier/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/SemiAutomaticClassificationPlugin/core/utils.py", line 4824, in multiProcessRaster
manager = cfg.MultiManagerSCP()
File "/Applications/QGIS3.10.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python3.7/multiprocessing/context.py", line 56, in Manager
m.start()
File "/Applications/QGIS3.10.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python3.7/multiprocessing/managers.py", line 547, in start
self._address = reader.recv()
File "/Applications/QGIS3.10.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python3.7/multiprocessing/connection.py", line 250, in recv
buf = self._recv_bytes()
File "/Applications/QGIS3.10.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python3.7/multiprocessing/connection.py", line 407, in _recv_bytes
buf = self._recv(4)
File "/Applications/QGIS3.10.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python3.7/multiprocessing/connection.py", line 383, in _recv
raise EOFError
EOFError
Version de Python : 3.7.3 (default, Mar 27 2019, 09:23:15) [Clang 10.0.1 (clang-1001.0.46.3)]
Version de QGIS : 3.10.9-A Coruña A Coruña, bf47e9d3e1
Chemin Python :
/Users/olivier/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/spatial_query_with_values
/Applications/QGIS3.10.app/Contents/MacOS/../Resources/python
/Applications/QGIS3.10.app/Contents/MacOS/../Resources/python/plugins
/Applications/QGIS3.10.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python37.zip
/Applications/QGIS3.10.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python3.7/lib-dynload
/Applications/QGIS3.10.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python3.7/site-packages/geos
/Applications/QGIS3.10.app/Contents/Resources/python
/Users/olivier/Documents/Donnees_QGIS
#2 Sat 28 November 2020 15:44
- othx
Re: QGIS/Module SCP: reflectance de surface
Toujours au sujet du module Semi-Automatic Classication PlugIn (SCP), j'ai également ce problème :
2020-11-28T15:11:21 WARNING warning:/Users/olivier/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/SemiAutomaticClassificationPlugin/core/utils.py:4176: DeprecationWarning: invalid escape sequence \(
g = cfg.reSCP.findall('nodata\(\"#?(.*?)#?\"\)',expression)
J'utilise MacOs High Sierra 10.13 avec QGIS 3.10.12
#3 Mon 30 November 2020 12:36
- othx
Savez-vous s'il existe d'autres forums où je pourrais adresser ces questions svp ?
Olivier
#4 Mon 30 November 2020 14:11
- Pascal Boulerie
- Lieu: France
- Site web
Savez-vous s'il existe d'autres forums où je pourrais adresser ces questions ?
georezo étant une référence francophone pour QGis, je pense qu'il vous faudra chercher des groupes d'utilisateur anglophones ou mondiaux (et donc anglophones), dont la liste est sans doute disponible indirectement dans la page Support de QGis :
https://qgis.org/fr/site/forusers/support.html
#5 Mon 30 November 2020 14:33
- SANTANNA
- Moderateur
- Lieu: Angers
Je vous invite aussi à voir dans quelle mesure ces erreurs ne sont pas déjà signalées sur le "portail" de développement de l'extension, à https://github.com/semiautomaticgit/Sem … gin/issues et éventuellement corriger cette lacune. Peut-être l'auteur vous indiquera un moyen de corriger si c'est local, ou corrigera et publiera une nouvelle version?
