#1 Fri 14 June 2019 11:16
Helene F.
QGIS 3.6.3: CADASTRE - Erreur import
Avez vous connaissance de ce type d'erreur lors de l'import des fichiers fonciers?
Utilisant ce plugin depuis plusieurs versions, je n'y avais jamais été confrontée.
Pouvez vous m'aiguiller sur une solution potentielle?
Par avance, merci pour votre appui !
"Une erreur est survenue lors de l'éxécution du code Python:
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xe7 in position 5883: invalid continuation byte
  File "C:/Users/HELENE/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\cadastre\cadastre_dialogs.py", line 727, in processImport
    qi.importMajic()
  File "C:/Users/HELENE/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\cadastre\cadastre_import.py", line 444, in importMajic
    item['method']()
  File "C:/Users/HELENE/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\cadastre\cadastre_import.py", line 581, in importMajicIntoDatabase
    for a in self.chunk(fin, self.maxInsertRows):
  File "C:\PROGRA~1\QGIS3~1.6\apps\Python37\lib\codecs.py", line 322, in decode
    (result, consumed) = self._buffer_decode(data, self.errors, final)
Version de Python : 3.7.0 (v3.7.0:1bf9cc5093, Jun 27 2018, 04:59:51) [MSC v.1914 64 bit (AMD64)]
Version de QGIS : 3.6.1-Noosa Noosa, 2468226bc9
Chemin Python :
C:/PROGRA~1/QGIS3~1.6/apps/qgis/./python
C:/PROGRA~1/QGIS3~1.6/apps/qgis/./python/plugins
C:\Program Files\QGIS 3.6\bin\python37.zip
C:\PROGRA~1\QGIS3~1.6\apps\Python37\DLLs
C:\PROGRA~1\QGIS3~1.6\apps\Python37\lib\site-packages
C:\PROGRA~1\QGIS3~1.6\apps\Python37\lib\site-packages\win32
C:\PROGRA~1\QGIS3~1.6\apps\Python37\lib\site-packages\win32\lib
C:\PROGRA~1\QGIS3~1.6\apps\Python37\lib\site-packages\Pythonwin
C:\Users\HELENE\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\cadastre/forms
C:\Users\HELENE\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\cadastre\forms
C:\Users\HELENE\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\cadastre\forms"
